Cv joint
50,000 MILES • 3.0L • 4 CYL • TURBO • 4WD • MANUAL
PAUL LINDLEY
Out of four wheel drive passanger side cv disengage but drivers side wont.
Sep 3, 2016 at 6:27 AM
SQM
  • 6,383 POSTS
After you remove the hub there is nothing keeps the CV axle in place. It will simply pull out of the housing.
Here is a helpful video, it is on a F150 but the setup is similar to your vehicle:
https://youtu.be/PNSWxzqrRK0
https://www.2carpros.com/articles/how-a-cv-joint-works
I have attached the replacement procedure just in case there was step might have gotten missed.
Oct 18, 2021 at 12:00 PM
