CV axle removal from the front differential
2,007,000 MILES • 2.7L • 4 CYL • 4WD • MANUAL
JASONHUETT2011
I have removed the whole front differential from my truck. I am not quite sure if that is what I was supposed to do. I need to know how to remove the CV axles from the front differential and replace them (the CV axles) with a new ones. Please reply back soon as possible, I am in a bit of a rush. Thank you in advance.
Nov 26, 2017 at 7:55 AM
STEVE W.
  • 15,389 POSTS
The axles just "pry" out of the axle tubes, there is a snap ring that is inside them that locks them in place. They will snap free, then install the new ones by lining up the splines and ram them in hard to get the snap rings to lock in. Pulling the differential is a bit more than a shop would do, normally you would pop the lower ball joint and turn the wheel hard to each side in turn as you removed them, but both get the job done.
Nov 28, 2017 at 3:51 AM
