CV Axle keeps breaking?
106,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JILL OWENS4
I had just recently replaced my bearing, hub, sway bar link on my driver's side and a day later my CV axle went out. I have replaced it twice now because as soon as I start to drive the new one breaks! I am stumped on what else it could be. Any thoughts on what I need to look at or do at this point? Any information would be greatly appreciated!
Thanks,
JO
May 5, 2025 at 1:55 AM
  • 55,597 POSTS
Yes, I have seen the engine/transmission mounts break or go bad allowing the engine to move excessively. I would have a helper start the car and with the hood open watch the engine while the car is put into drive and then reverse with a slightly elevated idle to watch the movement. If the engine wants to jump out of the car you have found the problem. Please upload pictures or videos in your response.
May 5, 2025 at 3:30 AM
JILL OWENS2
Okay, I will try that then.
May 5, 2025 at 3:33 AM
  • 55,597 POSTS
Sounds good, let me know how it goes.
May 5, 2025 at 4:12 AM
