CV axle replacement, old axle is stuck cannot remove it
153,000 MILES • 4.3L • V8 • 4WD • AUTOMATIC
BWHITMORE913
I am trying to replace the driver’s side CV Axle. The old axle is stuck in the transmission. Everything I am finding suggests it should just pull straight out. It may need some help with a pry bar. I have thrown everything I can think of at it but it is still stuck. Ideas?
Jan 3, 2020 at 1:14 AM
You need to use a slide hammer. You are correct that this just pulls out but when they are in there for a while they get rusted and don't want to come off easily.
Here is a video of them using one. Clearly you will need to attach yours differently but you get the idea.
You can rent these at a parts store.
https://youtu.be/NgxHZvgckuc
If you don't have access to this then you want to grab hold of the outer shaft and pull it outward in sudden movements. Basically you are looking for the shock to the inner shaft so that it breaks that corrosion loose that are on the splines.
Let me know if you have questions but this is the best way to free them that I have found and I think I have tried them all.
Jan 3, 2020 at 11:08 AM
