CV axle
187,333 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
CHRISTOPHER IVAN ROEDER
  • 156 POSTS
I was in drive through and when I turned I heard a pop It looked to be like something on the suspension snapped because the car won't move now unless it's towed.It looks like my axle or something in the vicinity is broke. I found three round bearings I believe covered in silver ooze not sure exactly but thought maybe a CV problem.
Jun 9, 2019 at 5:09 AM
I would agree this is the most likely issue. Those bearings sound like they are out of the CV axle.
I attached a few links here that will help but I have not heard anything that would make me think anything other than a CV axle.
https://www.2carpros.com/articles/symptoms-of-a-bad-cv-axle-joint
https://www.2carpros.com/articles/replace-cv-axle
Let me know if you need anything else. Thanks
Jun 9, 2019 at 8:13 AM
  • 156 POSTS
I will picking it up tomorrow from impound. thank you very much in the meantime.
Jun 9, 2019 at 11:58 AM
Sounds good. I will wait to hear back from you. Thanks
Jun 9, 2019 at 12:01 PM
  • 156 POSTS
So I've got the new CV axle in and also had to replace my ball joint now reassembling and having a hard time getting the castle nut back on the tie rod end to finish but almost there.
Jun 17, 2019 at 2:47 PM
Okay. Let me know what is giving you trouble with it and I will help how I can. Otherwise, I will wait to hear back.
Jun 17, 2019 at 10:17 PM
  • 156 POSTS
On to putting the caliper back on then I should be done. thanks for all the help.
Jun 18, 2019 at 2:26 PM
You are welcome. Thanks for using 2CarPros.
Jun 18, 2019 at 11:14 PM
