CV axle replacement
158,000 MILES • 2.0L • 2WD • AUTOMATIC
JANETTE LUVZ KEVIN
I'm trying to replace my CV axle and the six bolts on the inner part of the axle connected to the transmission are stuck. i have try everything and it wont budge. what can i do to get these six bolts off?
Apr 2, 2019 at 10:20 AM
SCGRANTURISMO
  • 4,897 POSTS
You can start by getting a quality lubricant, like PB Blaster or better and soak the heck out of them and leave them overnight. Get a quality 1/2" drive 6 point socket on them with a 1/2" drive ratchet. Next get a strong two or three foot pipe and slide over the ratchet. This is what is known as a "cheater bar". The longer you can make the cheater bar the more leverage you can get on the ratchet, which is turning the socket, which is turning the bolt. What did Archimedes say, "Give me lever long enough and I can lift the earth", this is the concept. It should break the bolt free. Get back to us and let us know what happens.
Thanks,
Alex
2CarPros
Apr 2, 2019 at 5:12 PM
JANETTE LUVZ KEVIN
We tried that and it did not work. Been working on it for the past three days and still no progress. we really don't know what to do anymore and have no car at this time. That is pretty much the only thing that we need to get done so we can install the new CV axle. please help..
Apr 2, 2019 at 7:29 PM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Last resort would be to drill the bolts out and retap the holes. Get back to us with what you find out.
Thanks,
Alex
2CarPros
Apr 4, 2019 at 5:51 AM
