Shuts off while driving
2003 NISSAN MARCH
80,000 MILES • 2WD • AUTOMATIC
RICH ISAAC
  • 11 POSTS
I have the vehicle listed above March k12 model. it just cuts off when I'm driving when I switch on the car it starts to work.
Jul 15, 2021 at 12:40 AM
SQM
  • 6,383 POSTS
There are several reasons for this to happen.
It could be vacuum related, fuel related or spark related.
Is the the check engine light on? Any codes?
This article might be helpful:
https://www.2carpros.com/articles/engine-cranks-excessively-before-starting
https://youtu.be/dCjmRL3p4Cs
https://youtu.be/vMwTzURWXmk
Let me know if you have any questions.
Jul 15, 2021 at 1:09 AM
RICH ISAAC
  • 11 POSTS
Good morning thank you for your generous support my car is Nissan March k12 2003 model its giving me problems firstly it looses power and then the temperature just goes up through the radiator for damaged. I took it to the mechanic he said I need a throttle sensor and pedal sensor and temperature sensor. This happened after throttle sensor was fixed.
Jul 15, 2021 at 2:07 AM
SQM
  • 6,383 POSTS
If this issue did not exist before the throttle sensor was fixed/replaced, then odds are the issue might be with the throttle sensor. These throttle bodies requires reset after replacement. This also could be because of a air leak after the air flow meter.
Might also be worth checking the wiring and connector to the airflow meter for any signs of corrosion or damage. you can do a quick fault find if you unplug the meter and run the engine without it.
Thanks.
Jul 15, 2021 at 2:16 AM
RICH ISAAC
  • 11 POSTS
The throttle was not replaced it was cleaned.
Jul 15, 2021 at 2:39 AM
SQM
  • 6,383 POSTS
I think it is still worth verifying there are no leaks or loose connector. Thanks.
Jul 15, 2021 at 2:46 AM
RICH ISAAC
  • 11 POSTS
Thank you so much.
Jul 15, 2021 at 2:59 AM
SQM
  • 6,383 POSTS
Please let me know if you have any other questions.
Thank you!
Jul 15, 2021 at 3:01 AM
RICH ISAAC
  • 11 POSTS
I'm having challenges with my sensors temperature and throttle sensor for my Nissan March k12 2003 model I'm Zimbabwe I usually get second hand. are you able to help me get new ones or refer?
Jul 15, 2021 at 3:04 AM
SQM
  • 6,383 POSTS
Check out this website, they offer used parts for your Nissan. I am not sure what the shipping cost will be though.
https://autoparts.beforward.jp/search/NISSAN/MARCH/2003/
Thanks.
Jul 15, 2021 at 3:19 AM
