Engine cuts out when warmed up
180,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
SHERI LAMPARTY
When the car gets up to temperature it wants to start cutting out wanting to shut off. If I turn the heater on it helps it from cutting out for minute or so.
May 7, 2021 at 6:59 AM
Good afternoon,
This could be either the crankshaft position sensor where the signal is dropping out or it could be the ignition control module which is common.
https://www.2carpros.com/articles/engine-stalls
I would remove the module and take it to a parts store and have it tested. It is a free service.
May 7, 2021 at 8:49 AM
SHERI LAMPARTY
Both of those sensors have been replaced.
May 7, 2021 at 8:24 PM
The ignition control module is not a sensor.
What other sensor beside the crank sensor did you replace?
May 7, 2021 at 10:22 PM
