Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Renault
Megane
Engine
Symptoms
Misfire
cutting out
1997 RENAULT MEGANE
147,000 MILES • 1.6L • 4 CYL • RWD • MANUAL
ALISON TUCKNOTT
MEMBER
1 POST
my car is only running on 3 cylinders, it stalls constantly, and the water container needs filling everyday but its not leaking.
Apr 30, 2016 at 12:14 AM
CJ MEDEVAC
Experienced Mechanic
SOUNDS LIKE A HEAD GASKET ISSUE
PRESSURE TEST THE COOLING SYSTEM
A COMPRESSION TEST MIGHT ALSO BE IN ORDER
IF WATER IS GETTING IN A CYLINDER, THAT PLUG WILL HAVE A DIFFERENT COLOR AT THE ELECTRODE THAN THE OTHERS.
THE MEDIC
Image (Click to enlarge)
Apr 30, 2016 at 10:46 AM
Add image or video
Ask a new question
Engine won't start
Engine misfire
