car will start but shuts off after three seconds?
160,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
GARNETALBRIGHT
The flapper in the throttle body is not opening so only the air in the chamber is being used, I changed the throttle body and the same issue. There are no codes in the ECU and the Throttle relay is closing when I turn the key. There are no blown fuses, and the car has been working perfectly for years.
Mar 14, 2023 at 8:38 AM
  • 55,616 POSTS
Is the security light flashing? if so the alarm system is activated, you can try a hard system reboot which is done by removing the negative side of the battery, with the cable loose from the negative side of the battery, hold it to the positive terminal for 1 minute this will discharge the memory capacitors in the BCM and PCM allowing the system to reboot.
Please check out this guide:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
and
https://www.2carpros.com/articles/how-to-reset-a-security-system
Please go over this guide and report back.
Mar 15, 2023 at 4:59 AM
