I have posted this problem a number of times.If I have a misfire in cylinder 2.This is coil on plugs.Can I pull the wire on number 2 you know like you use to be able to do when a cylinder was cutting out pull a spark plug wire to see what cylinder is was.And I would like to know is how you test the injectors to see if it is bad?
May 18, 2013 at 4:42 AM
