Cuts off while driving
129 MILES • 2WD • AUTOMATIC
JOBRIEN2269
ABS light comes on, radio goes off, a light comes on that has a lock on it and then the engine loses power and shuts off. we just replaced the battery last night.
what else could be wrong?
Aug 23, 2019 at 12:02 AM
BMDOUBLE
  • 1,139 POSTS
You could have an issue with your charging system and or alternator. All of the warning lights are coming on because the modules in your vehicle are shutting down due to the low voltage. You will need to have your charging system tested to verify this. This will need to be done first and then we can proceed further if there are other issues. Here is a guide for the charging system: https://www.2carpros.com/articles/how-to-check-a-car-alternator
Aug 23, 2019 at 12:58 AM
