cuts off when put in drive
144,000 MILES • 4 CYL • 4WD • AUTOMATIC
DAVID103
  • 13 POSTS
car cuts off when put in drive. code p1614.
Aug 1, 2017 at 3:15 AM
  • 55,766 POSTS
It sounds like you may have two problems, that code is for the security system triggered. is the security light flashing? Next does it stall in both drive and reverse?
Please let us know.
Cheers, Ken
Aug 2, 2017 at 9:29 AM
DAVID103
  • 13 POSTS
only when you put it in drive.
Aug 2, 2017 at 1:44 PM
DAVID103
  • 13 POSTS
and I think the mil light has been disconnected.
Aug 2, 2017 at 1:45 PM
  • 55,766 POSTS
If the engine runs okay when you put it in reverse but stalls when you put it in gear then I would check the air intake boot for tears. When the engine shifts in its mounts it can cause the tear to open causing the engine to stall. here is a guide to help you confirm the problem:
https://www.2carpros.com/articles/replace-an-air-intake-boot
Cheers, Ken
Aug 3, 2017 at 3:17 AM
DAVID103
  • 13 POSTS
air intake boot okay, still shuts off when put in drive
Aug 4, 2017 at 2:18 AM
DAVID103
  • 13 POSTS
lights not working on dash, how do I reset security code?
Aug 6, 2017 at 5:04 AM
  • 55,766 POSTS
Disconnect the battery for 30 minutes and then reconnect it. Next unlock the car using the remote and you should be good.
Aug 7, 2017 at 3:30 AM
DAVID103
  • 13 POSTS
no remote, key only
Aug 7, 2017 at 1:26 PM
