Cuts off
JDUBBED
  • 2000 JEEP GRAND CHEROKEE
  • 184,331 MILES
Engine light is on, turned the ignition 3 x and got p0443 code.
Whenever it starts to get warm outside, or the jeep has been running a while (nice and warmed up) it just cuts off at lights or even while driving.
Monday, April 29th, 2013 AT 3:26 AM
HMAC300
  • 48,601 POSTS
443 is the evap canister purge solenoid check to make sure it is getting power. Check your fuel pressure and then check crank sensor connection as well as resistance it may be tohigh when hot and cutting off.
Monday, April 29th, 2013 AT 7:09 AM
