Alarm sounding for no apparent reason
195,000 MILES • 2WD • AUTOMATIC
JOEL MACDOUGALL
The alarm goes off sometimes even when the car is not locked. usually two to three times a day. In the past it has been observed to trigger the alarm when another car was locked.
Apr 30, 2019 at 2:37 AM
  • 55,688 POSTS
This can happen when the drivers door latch wears causing the mirco-switch inside the latch to be triggered. I would unplug the latch to see if it goes off, if not replace the latch. You will need to remove the door panel, here is a guide to help walk you through the steps.
https://www.2carpros.com/articles/door-panel-removal
Please let us know what you find.
May 2, 2019 at 6:58 AM
