Does intake manifold have to come off? to pull motor through front? already cut radiator support and such.
Jun 15, 2019 at 12:17 PM
STEVE W.
✓Experienced Mechanic
Welcome to 2CarPros. To give you enough room to pull it out the front you need to remove the intake and the engine mounts. Normally I drop them out the bottom but I've assisted with front removal as well.
