Shut off while driving and will not restart?
200,000 MILES • 4 CYL • AUTOMATIC
KANDY31210
I was going up the road and it just quit and won't start back now.
Aug 6, 2022 at 9:13 AM
  • 110,248 POSTS
In most cases, this happens either as a result of a fuel problem or ignition. The timing belt also could have jumped or broken.
Here is what I suggest: See if it will start for a couple seconds using starting fluid. If it does and then stalls, suspect a fuel-related issue. If there is no change, I need you to check for spark to the plugs.
Here is a link that explains how that is done:
https://www.2carpros.com/articles/how-to-check-for-ignition-spark
Also, if you could possibly record it cranking and upload it for me to hear, I should be able to tell if it is a timing belt-related issue.
Aug 6, 2022 at 2:43 PM
