Cut off and will not start, information screen went blank
100,000 MILES • 6.0L • V8 • 2WD • AUTOMATIC
LAWRENCE FOSTER2
I was just sitting in my car it was running while I waited on my friend. we pulled off then the car started running rough then cut off and the information screen went blank.
Apr 13, 2019 at 5:40 PM
SEVAG P
  • 405 POSTS
hello thanks for using 2CarPros.
is check engine on? there are many causes that can make these problem,fuel system ignition system,crank sensor,or alarm,as a first step fault codes must be checked to narrow our problem and for faster troubleshooting.
please send us the fault codes.
check our guide for reading fault codes:
Apr 13, 2019 at 7:34 PM
