Custom fuel filter installation
80,000 MILES • 2.0L • 4 CYL • 2WD
BRYCE CLINE
  • 32 POSTS
My car listed above 3i has an unserviceable fuel filter. I want to add one that is accessible and efficient.
I don't like the fact of no filter and where all the debris goes. Is there a filter recommended that is tolerable of the pressure and efficiency without causing issues?
Is there a particular place that they have been installed?
Thank you
Jun 11, 2020 at 11:25 AM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
There is a filter system in the fuel tank. it wouldn't be recommended to add another filter as it would most likely interfere with the system possibly causing performance issues as well as a check engine light. Restricting the fuel flow could result in engine damage due to a run lean condition causing detonation. My recommendation is to trust the engineers that designed the system.
Jun 11, 2020 at 10:14 PM
