Rebuild an LS 5.3 engine?
113,000 MILES
VOLS
I have watched your how to rebuild an LS 5.3 probably 20 times the whole series. my question is, will it apply to rebuilding?
Lq9. 6.0
Feb 23, 2025 at 8:59 AM
RYAN L
  • 273 POSTS
Yep, everything should directly translate! I believe the only difference is the bore so double check that before you order pistons.
Thank you so much for watching the series and for using 2CarPros! If you have anymore questions, come on back!
Feb 24, 2025 at 3:20 AM
