Codes P1773 (twice) and C2116?
12,000 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
BZZZZZZ
Low air light, ABS warning, ASC off, Service engine soon light OBDII codes=
P1773 (twice?) and C2116 These seem to have nothing to do with EPA emissions, so why do I not pass the A.I.M (Ohio) emission test?
Nov 14, 2022 at 1:17 AM
  • 55,694 POSTS
C2116 Code - The Electronic Stability Control (ESC) may also be referred to as Electronic Stability Program.
The P1773 code is that you have an ABS fault.
So, both of these codes can be caused by a Wheel Speed Sensor that is not working correctly which usually happens when a front brake hub goes out, do you have a low hum in the front when driving? If so, this is a sign the bearing hub has gone out. You should be able to pass the Emission test but if the warning light is on, they might have an issue with it. You can run the codes to find out which sensor is giving you the problem.
This guide can help:
https://www.2carpros.com/articles/anti-lock-system-testing-and-repair-abs
Also, i have included the instructions on how to change the front bearing hub out in case you need it. Here is a video of the job being done on a similar car as well. the front and rear operation is the same.
https://youtu.be/_FzmmBoa4Tg
Check out the images (below). Please let us know what you find. We are interested to see what it is.
Nov 14, 2022 at 2:51 AM
BZZZZZZ
Thanks for the quick response, the BMV folks could not answer why brake system codes would cause the vehicle not to pass.
Nov 14, 2022 at 3:05 AM
  • 55,694 POSTS
Good to hear, please use 2CarPros anytime we are here to help.
Nov 16, 2022 at 5:11 AM
