Overheating even after replacing a lot of components?
167,000 MILES • 1.4L • 4 CYL • TURBO • AUTOMATIC
ALLISON JG
Hi there! The engine keeps overheating and losing coolant (no coolant leak).
I have replaced the thermostat, water pump, turbo, and fan.
I was wondering if a bad ECT sensor could make the engine heat to the point where the coolant is boiling and spitting out?
I know that I have to replace the crank seal because I'm losing a little bit of oil, is that related as well?
Apr 8, 2025 at 3:43 AM
STEVE W.
  • 15,385 POSTS
That isn't a good sign, losing coolant and overheating are classic signs of a bad head gasket. I would pressure test the cooling system, then use a combustion gas test.
https://www.2carpros.com/articles/radiator-pressure-test
See if it passes both. You could also pull the spark plugs; they should be a tan-brown color. If you find one or more that are very clean or look glazed, it's the head gasket.
Apr 8, 2025 at 8:18 AM
