Last week i tried to put on the cruise Control but it did not work. And No cruise control light on.
Oct 13, 2024 at 12:52 PM
✓Experienced Mechanic
Okay, the first thing we should do is check the #2 fuse in the fuse panel at the center of the dash and the fuse # 28 in the fuse panel under the hood. here is a guide to help and I have included the fuse location in the images below.
Hi Ken L! I just checked the 2 fuses, and they are okay (no burn fuses). Do you have another idea that i can try? If i am in a parking an i put on the Cruise control, will i see the light on in my dash? Because the light of cruise control, do not get on. Thanks' for helping!
Jean G
Oct 14, 2024 at 6:11 AM
If the light is not coming on and the fuses are good, there is a circuit error. A common place for the failure is the clock spring (spiral wire) behind the steering wheel. Here is the cruise control wiring diagrams and a guide to help test through the wire and how to replace the clock spring if it tests bad.
