I didn't notice after service that the cruise control no longer worked. I noticed a few months later and have been too busy to deal with it.
I adapted to not having cruise control and rarely think about it.
It has now been over 8 months since the service.
My assumption is that they forgot to hook some wire back up.
The button does not react with any lights on the dash as if disconnected.
The car does not have any lights indicating trouble on the dash.
I know I will need to have it scanned for codes to see if anything shows up.
I am hopeful for information on any possible wire that could have been left unplugged while changing out the actuator or a possible fuse I could check for needing replacement.
Would a wire being disconnected under the dash cause this? If so would it produce a code?
I would not think that they would have needed to remove the steering wheel to cause issues with the wires to the clock spring but it is a possibility.
Appreciate any suggestions. Thank you
Oct 28, 2020 at 1:13 AM
