Cruise control lights both turn on, but it does not engage?
2002 HONDA CRV
280 MILES • 2.4L • 4 CYL • 4WD • AUTOMATIC
LEO N REYES
  • 5 POSTS
Cruise control not working properly.
Oct 9, 2022 at 9:35 AM
  • 110,240 POSTS
Are there any lights staying on such as ABS, traction control, stability control, or others?
If there are no other lights, the first thing I want you to check is the actuator cable that attaches to the throttle body. Make sure it is properly installed and not damaged.
See pics below. Pic 1 shows the end which goes to the throttle body. Pics 2 and 3 are from the actuator motor that actuates the Cruise Control.
Let me know what you find. Also, let me know about any lights.
Oct 9, 2022 at 12:29 PM
LEO N REYES
  • 5 POSTS
Hey, thanks for your response and yes, all lights are on the dash.
I will check what you mentioned.
Oct 9, 2022 at 1:38 PM
  • 110,240 POSTS
Chances are it's not the cable if the lights are on.
If the ABS or traction control lights are on, the cruise control won't work. Have you had the computer scanned for codes? My first suspect would be a faulty wheel speed sensor.
You can check each wheel speed sensor using a voltmeter or multimeter. Having the can-bus scanned will save you time. If you want to check them at home, here is a link that explains how it's done:
https://www.2carpros.com/articles/abs-wheel-speed-sensor-test
Let me know your thoughts or if you have other questions.
Oct 10, 2022 at 11:31 AM
LEO N REYES
  • 5 POSTS
It was the cable! Thanks
Oct 11, 2022 at 1:13 PM
  • 110,240 POSTS
Thank you for the update. I'm glad to know you found the issue. Please feel free to come back anytime in the future if you have questions.
Oct 11, 2022 at 1:51 PM
