Does a used cruise control module need to be reprogrammed to your VIN like an ECM?
Apr 28, 2022 at 4:24 AM
STEVE W.
✓Experienced Mechanic
No, it is not an active control module on that car that needs programming. The only things it gets from the ECM are the switch inputs for the neutral switch and the speed input from a wheel sensor.
