Cruise control
150,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
ALF MEREDITH
After replacing the speed sensor, the cruise control light on the button turns on however, the dash light does not come on and the cruise control itself does not work.
Aug 15, 2016 at 12:46 AM
HMAC300
  • 48,601 POSTS
have it scanned for codes and check brake switch for staying on as well as fuses and ground for cruise. there are two speed switches that it operates off of counter-shaft and main speed switches. you may have to have it scanned for codes as well as it could be the cruise unit itself.
Aug 15, 2016 at 2:42 AM
