Crossed jumper cables, now multiple electrical issues
127,000 MILES • 3.7L • V6 • 2WD • AUTOMATIC
BEN9784
I had a very bad morning and crossed my jumper cables while trying to revive a new, but dead battery. I eventually got it jumped correctly and the battery has held a charge and seems fine, I have been driving it without any noticeable issues except:
1. Interior lights do not work. I found the fuse blown but haven't replaced yet.
2. Radio/clock does not work. fuse tested fine.
3. Tire pressure sensor light will not turn off. I have checked tire pressure and they are within range to where this light should not be on.
4. The car will not start with the wireless remote/push start. I have to take out the over-ride key and insert it to start the vehicle and I cannot unlock doors remotely. However, once the car is started power door locks work correctly from inside the car.
My question would be, what should be checked next to get the radio functioning and key-less systems back for someone not very mechanically inclined?
If this is not something for an amateur, any idea how long of a job this could become if taken to a shop?
Jun 18, 2020 at 3:08 AM
CARADIODOC
  • 34,417 POSTS
There are going to be multiple blown fuses. Everything you mentioned is now run by computers. Those always have a "diode" inside between the power and ground terminals. Diodes are one-way valves for electrical current flow. Under normal conditions, the diodes are placed in the computer backward so it is turned off and doing nothing. It's when the battery or jumper cables are connected backward that the diodes become "forward-biased" and act like a piece of wire. They become a dead short that forces the fuse to blow. In so doing, the computer is protected from that reverse polarity. In very rare instances a computer module can still be damaged, but most of the time, it is simply a matter of replacing all the blown fuses.
There are two fuses for the radio. One is for the switched circuit that turns the radio on with the ignition switch. The other one is always on to maintain the radio's station presets and clock in memory. Most computers also have memory circuits that are separate from their regular fused circuits. That radio's memory circuit is rarely on its own or with its own fuse. Instead, it is tied in with some other circuit that is always live. That is very commonly the interior light circuit. It could also be the horn or cigarette lighter circuit.
There's two things to be aware of. The first is to make life miserable, on the majority of import cars, one of the radio's fuses is plugged in on the back of that radio. That means you have to pull the radio out to check or replace that fuse. They're usually a red 10-amp fuse.
The second issue has to do with how the radio acts when the memory fuse is blown. It is important to understand that different radio models behave differently, so don't go by what someone else tells you happened to their radio. Some radios will be totally dead, even though the main radio fuse is okay. Some models will work perfectly normally until you turn them off, either at the radio or with the ignition switch, then, when you turn them back on, the radio station will have reset to a factory-preprogrammed setting, and the clock will have reset to 12:00 or the setting used at the factory. Some radios will have working displays, and you can tune them up and down, but there will be no sound.
The fuses that typically blow from reversed jumper cables are the smaller ones. Those will have two tiny holes on top for test points. Use a test light to check for voltage on all the fuses, both test points, with the ignition switch on. If you find 12 volts on both test points, that fuse is okay. If you find 0 volts on both points, that circuit is currently turned off. You're looking for any fuse that has 12 volts on one side and 0 volts on the other side. That one is blown.
Here's links to some articles that will explain this better:
If you don't have a test light, a digital voltmeter will work too:
I can help you with setting it up, if you need it.
Jun 18, 2020 at 10:25 AM
BEN9784
I used a Bussmann fuse tester (attached picture) to test the fuses, but I did not have the car turned on in any way while doing it. I’m guessing this only detects a blown fuse and not a fuse that does not have power flowing through it from another source. I did pull the radio fuse and visually checked it, and it did not appear blown.
Does this style tester tell me anything or do I need to go get a light tester to test all the fuses again with the ignition on?
Jun 18, 2020 at 11:23 AM
CARADIODOC
  • 34,417 POSTS
I'm not familiar with that tester. If it has a small battery inside, it is checking for continuity through the fuse, which should be sufficient.
I was in tv / vcr repair for 35 years, along with auto repair including electrical for almost as long, so a test light is a standard part of my tools. With either a test light or your tester, they aren't of much use for the large fuses that don't have test points on them. All of us are frustrated that checking them can be a time-consuming, tedious job. It is often hard to tell visually if they're okay.
I still think there are some blown fuses that were overlooked. If not, we'll need to pick one dead circuit and concentrate on that. I'd pick the radio since those are the most similar between car brands and models. If we need to go that route, have the radio pulled out with the plug accessible for taking voltage readings. Here again a test light should work fine, but if you have a digital voltmeter, that will work too.
This diagram is part of the base radio system. Note there's actually four fuses shown. The two in question are shown in the drawing. It's hard to read, so I added the nifty pink and red arrows.
Jun 18, 2020 at 11:34 AM
