Cross threaded spark plugs?
2002 HONDA ACCORD
224,000 MILES • 4 CYL • 2WD • AUTOMATIC
NEWBZZZZ123
My nephew has the car listed above and he had accidentally cross threaded the spark plugs 2-3 months ago and now it started overheating and cutting out when driving it. Is that a complication of the cross threaded plugs?
Nov 13, 2024 at 9:55 AM
  • 110,244 POSTS
How were the threads repaired? Are you getting a code indicating the misfire is coming from the same cylinder where the damage was done?
As far as your question, make sure there isn't a leak around the spark plug where the threads were repaired. Other than a compression loss due to a leak, if you repaired the threads, that wouldn't be the cause.
Nov 13, 2024 at 10:41 AM
NEWBZZZZ123
As far as i know, they weren't repaired. The code it threw was saying it just needed a tune up.
Nov 14, 2024 at 3:59 AM
  • 110,244 POSTS
If he could reinstall the spark plug, it is tight and has no issues; cross-threading itself isn't the issue. if possible, let me know how the cross-threading was resolved.
I need to know the diagnostic code or codes it has. It sounds like he replaced the plugs a few months ago, so I'm unsure which direction to point you in without knowing the code. What you described can indicate a few different things and I don't want to misdirect you.
If possible, let me know what codes are present. That will help me determine what to check and I would be happy to further help with the issues.
Nov 14, 2024 at 12:01 PM
