Creaking sound from rear left wheel when slowly reversing
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
SEANWMCQ
Hi there,
There is creaking sound (like an old door that needs oil) coming from rear left wheel when slowly reversing.
Drove on highway for an hour then felt all the hubs and all hubs had the same temperature not hot also no rocking or grinding sounds with the rear right wheel.
Would this possibly be a bushings or axle issue?
Thank you,
Sean
Apr 25, 2019 at 10:32 AM
  • 110,248 POSTS
Welcome to 2CarPros.
Most times, it is related to a bushing. However, the Canadian version of this vehicle has a technical service bulletin (TSB) regarding abnormal noise from the rear. I'm not sure if you are located in Canada, so I will provide the TSB. The attached pictures correlate with this bulletin.
Note: If you are not in Canada, the last picture I will attach is an exploded view of the rear suspension. You will see where all the bushings are located in the pic. You may want to try spraying them with a rubber friendly lubricant to see if the sound changes or goes away.
___________________________
Here is the TSB:
SUBJECT
REAR HUB BEARING AND DUST COVER INSTALLATION (REVISED)
This bulletin supersedes TSB 09-50-013-1 to provide updated warranty information for increased labour time. See warranty information for further details. Please discard the previous bulletin.
pic 1
Some Santa Fe vehicles equipped with the 4WD system may exhibit an abnormal noise originating from the rear hub. This may be caused by a damaged rear hub bearing due to debris entering through the 10mm gap between the dust cover (A) and the carrier (B) on Santa Fe vehicles.
pic 2
This bulletin provides the procedure for replacing the rear hub bearing and installing an improved dust cover to prevent damage caused by debris. The new dust cover reduces the gap between the dust cover (C) and the carrier (D) to 1mm.
AFFECTED VEHICLES
Some 2007~2009 Santa Fe (CM) vehicles produced from Job # 1 to April 8, 2009.
pic 3
PARTS INFORMATION
NOTE:
Each kit includes the components required to perform the procedure on ONE side of the vehicle; dealers must order two kits to complete the procedure on both sides.
SERVICE PROCEDURE:
pic 4
1.Release the parking brake.
2.Remove the left rear wheel from the vehicle by removing the wheel lug nuts (A).
Tightening torque: 9~11 kgf.m(88.3~107.8 N.m, 65.1~79.5 lbf-ft)
pic 5
3.Remove the mounting bolts (B) to remove the caliper assembly.
Tightening torque: 6.5~7.5 kgf-m(63.8~73.5 N.m, 47.0~54.2 lbf-ft)
pic 6
4.Place the caliper assembly in a position which will not pull on the brake hose.
pic 7
5.Remove the split pin (C) from the castle nut.
pic 8
6.Unfasten and remove the castle nut and washer (D).
Tightening torque: 20~26 kgf.m(196.2~254.9 N.m, 144.7~188.0 lbf-ft)
pic 9
7.Remove the brake rotor by unfastening the two screws (E).
pic 10
8.Using a jack, support the rear lower arm and remove the mounting bolt (F) facing toward the tire.
Tightening torque: 14~16 kgf.m(137.3~156.9 N.m, 101.3~115.7 lbf-ft)
pic 11
9.Remove the rear strut upper mounting bolt (G).
pic 12
10.Remove the rear strut lower mounting bolt (H) and remove the rear strut assembly.
Tightening torque: 10~12 kgf.m(98.1~117.6 N.m, 72.4~86.7 lbf-ft)
pic 13
11.Remove the trailing arm mounting bolt (I).
pic 14
12.Remove the four rear axle carrier hub mounting bolts (J).
Tightening torque: 8~9 kgf.m(78.5~88.2 N.m, 57.9~65.0 lbf-ft)
pic 15
13.Remove the rear hub assembly from the vehicle.
pic 16
14.Install the new dust cover with the raised edge facing outwards as shown.
pic 17
15.Set the dust cover and parking brake into position.
pic 18
16.Install the new hub bearing.
pic 19
17.Re-install all removed components in reverse order of removal.
IMPORTANT:
^ The washer which accompanies the castle nut (D) must be installed with the convex side facing outwards.
^ Be sure to use new split pins when reassembling components.
18.Repeat procedure on right side of vehicle.
_____________________________
Again, the last picture is the exploded view I mentioned. Let me know if this helps or if you have other questions.
Apr 25, 2019 at 12:41 PM
SEANWMCQ
Hi Jacob,
Thank you so much for your reply and this information it is much appreciated.
This is my daughters vehicle and yes this is a Canadian vehicle, she lives in Ottawa and will be travelling back to Toronto tomorrow about a four hour drive. Would this need to be dealt with right away or can she have it fixed when she comes back home?
Thank you again,
Sean
Apr 27, 2019 at 3:59 AM
  • 55,743 POSTS
I found this video for you to show you how to do the job on a similar car.
https://youtu.be/_FzmmBoa4Tg
Apr 27, 2019 at 4:01 AM
