Creak coming from steering wheel column when I turn the wheel
138,000 MILES
CHAZ4694
  • 8 POSTS
I have a creaking sound that I hear at low speeds from the steering column. when I turn the steering wheel It sounds like it is coming from just behind the firewall. I have shot some lubricant into this boot at the firewall and it quiets the noise for a period of time but it returns. Do you have an idea of what needs to be replaced to fix this noise. Or should I ignore it as a nuisance? Chrysler LHS 1999
Oct 14, 2013 at 11:06 AM
  • 110,248 POSTS
What boot are you spraying into?
Oct 14, 2013 at 11:23 AM
CHAZ4694
  • 8 POSTS
There is a rubber boot at the base of the steering column where it enters the firewall from the passenger compartment.
Oct 14, 2013 at 11:28 AM
  • 110,248 POSTS
check to see if it is a universal type joint. You may be able to get rid of the noise with grease.
Oct 14, 2013 at 11:33 AM
CHAZ4694
  • 8 POSTS
I greased the U-joint and it is a bit quieter, but still there. Does this need to be replaced? Or is it a nuisance noise? Not sure how expensive it would be to fix.
Oct 16, 2013 at 11:39 AM
  • 110,248 POSTS
Based on your description, it sounds like nothing but a nuisance noise. To replace it would be around 200.00. It will be labor intense.
Oct 16, 2013 at 11:49 AM
CHAZ4694
  • 8 POSTS
...which is why I do not want to attempt this repair on my own...thanks.
Oct 16, 2013 at 11:52 AM
