Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Taurus
Engine
Symptoms
Not Running
cranks no start
2000 FORD TAURUS
140,000 MILES • 3.0L • V6 • FWD • AUTOMATIC
STEVE ANN WATSON
MEMBER
car cranks but will not start. I checked crank sensor coil, fuel pressure, spark at front cylinders. need other ideas or areas to go to.
Jul 16, 2017 at 1:56 AM
Experienced Mechanic
Two things come to mind we should check to get started, First lets make sure the engine has compression.
Next lets see if the injectors have pulse.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Here is a guide to help you as well.
Cheers, Ken
Jul 17, 2017 at 10:54 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
