Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Fusion
Engine
Crankshaft
Sensor
Location
Crankshaft sensor(s) location to replace
2015 FORD FUSION
48,000 MILES • 1.5L • 4 CYL
DRIVERSRLTD
MEMBER
1 POST
Check engine light is on. Diagnosis indicated code for crankshaft sensor.
Jan 27, 2019 at 9:14 PM
SCGRANTURISMO
Experienced Mechanic
Hi Driversltd, my name is Alex and I will be helping you. Here is a couple of helpful links and some instructions on where and how to replace your crankshaft position sensor. Thank you and let us know if there is anything else we can help you with.
https://www.2carpros.com/articles/how-a-crank-shaft-angle-sensor-works
Images (Click to enlarge)
Jan 27, 2019 at 10:50 PM
BMDOUBLE
Okay, what code was this? I’ve never replaced a crank sensor just by code only. There are many condition codes that will have the word crankshaft sensor in them but there will be pinpoint test to rule out circuitry, timing, etc.
Jan 28, 2019 at 1:28 PM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
