Crankshaft sensor replacement
178,000 MILES
FAITH98
My car started to have a rough idle and wouldn’t let me gain speed. the RPM's would go down and I would slow down. Checked the engine light and it threw a mass airflow sensor code and a crankshaft position sensor code. I replaced both sensors. The car worked for about a day and then when it went to start it the next day I’m back to having the same issues. If I can finally get it to start the idle is very rough. Please help this is frustrating...
Dec 20, 2020 at 4:05 AM
  • 110,246 POSTS
Have the same codes returned? As far as the idle issue, that is usually caused by an engine vacuum leak, need of a tune-up, or fuel pressure.
First, let's check and make sure there are no vacuum leaks. Since you replaced the MAF, confirm the air inlet tube is properly attached. Also, here is a link that shows how to locate a vacuum leak:
That is where I would start. Let me know if the same codes have returned and I need to know the engine size, 2.2L or 2.4L.
Dec 20, 2020 at 2:20 PM
