Crankshaft sensor replacement procedure needed
120,000 MILES • 3.5L
VINNY528
what is the procedure to change the crank sensor? This vehicle is a Taurus X.
Apr 5, 2018 at 7:43 AM
Good evening.
Picture attached and procedure.
Removal and Installation:
1. With the vehicle in neutral, position it on a hoist.
2. Remove the left hand catalytic converter.
3. Remove the bolt, nut and the heat shield.
- To install, tighten to 10 Nm (89 lb-in).
4. Remove the rubber grommet cover.
5. Disconnect the crankshaft position (CKP) sensor electrical connector.
6. Remove the bolt and the CKP sensor.
7. To install, reverse the removal procedure.
Apr 5, 2018 at 10:37 AM
