Where are 2010 Nissan cube crankshaft position sensors located? Ive look we had others look find it. We are doing the work ourselves
Aug 8, 2026 at 11:20 AM
KRAKENAUTO
✓Experienced Mechanic
the crankshaft position sensor is located on the rear side of the engine block near the transmission bell housing, close to the passenger-side CV axle area and is likely protected by a small heat shield.
