Crankshaft sensor
184,000 MILES • 3.0L • AWD • AUTOMATIC
TAYLOR LINDSEY PIEFFER
I am trying to replace the sensor but I can not locate it. The care idles high only when stopped and in park.
Sep 23, 2017 at 11:57 AM
JOHNNYT73
  • 924 POSTS
The sensor should be located just above the center pulley (crankshaft pulley) under the metal shielding.
Sep 23, 2017 at 2:01 PM
STEVE W.
  • 15,420 POSTS
I doubt the crank sensor is the cause of a high idle. Rough idle, misfires, and no starts are common with a bad CPS.
High idle is usually a vacuum leak or sticking IAC, those let extra air into the engine that does not get measured by the ECM and you get a high idle. A small leak will not effect the engine once it gets off idle.
Testing for a vacuum leak is not difficult.
Sep 23, 2017 at 11:09 PM
