Crankshaft position sensor
220,000,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
ROBERT85387
I need to replace the crankshaft angle sensor can you help me please?
Feb 11, 2016 at 4:30 AM
JOHNNYT73
  • 924 POSTS
This video will show you how to replace the sensor with diagrams below to show you how on your car.
https://youtu.be/sKo7xRWVNqY
Here is how to replace the sensor with the sensor relearn procedures as well. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Feb 11, 2016 at 4:37 AM
ROBERT85387
thanks you worked perfect I cant believe this site if free :)
Feb 11, 2016 at 4:49 AM
JOHNNYT73
  • 924 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Feb 11, 2016 at 4:50 AM
JTHOLT
Engine Mechanical problem
1996 Chevy Cheyenne V8 Two Wheel Drive Manual
my truck has miss. I put it on a computer. It say there is a discorlation between the camshaft and the crankshaft sensors what does this mean? code(p1345)
Jan 18, 2021 at 2:19 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
In other words the cam is not where it is supposed to be in reference to the crank. It could be the Cam position sensor, the crank shaft position sensor , the gear on the distributor or the timing chain. The quickest and cheapest check is the distributor gear which is also the most common to fail between these components.
Thanks for using 2CarPros.com!
SETITS
c3500 2wd . I have been looking here and other sites for the location on this engine with no good results. I have looked at the engine and it is not on the front lower (passenger side 7 pm) location, or the drivers side at the harmonic balancer.
Jan 18, 2021 at 2:20 AM (Merged)
Danny is correct but just to elaborate a little bit on it. This engine due to it having a distributor uses a pick up coil in the distributor that picks up the rotation of the crank shaft. It sends pulses to the ignition control module and it uses this to determine engine timing.
I am attaching all the info below for your review. Let us know if you have other questions. Thanks
JAMES MARTIN4
So, I replaced my crankshaft position sensor, but a 2-wire plug came out of its plug on drives side of engine and i cannot find it location to plug it back in its a 1998 Chevrolet K1500 Silverado 5.0L.
Dec 9, 2024 at 6:02 PM
  • 55,859 POSTS
I am not sure what you are saying, can you clarify please?
Dec 10, 2024 at 2:33 AM
