Crankshaft sensor, code p0336
210,000 MILES • 4.3L • 6 CYL • 4WD • AUTOMATIC
RELTNEE5199
Wires came out of the plug, need to know wire colors to plug. Have yellow wire, purple or brown and looks like orange wire, Have 11.83 volts at orange or pink wire. Have voltage at pink wire at coil and control module. Have no spark out of coil. Will turn over but will not start. Shows code p0336. Need help.
Sep 23, 2018 at 11:03 AM
Good evening.
I will attach the wiring diagram for you to view. I will also post the 336 description and needed checks.
The code could be a result of the wiring being incorrect.
CIRCUIT DESCRIPTION
The Crankshaft Position (CKP) sensor is a sensor designed to detect changes in a magnetic field. The control module supplies the CKP sensor a signal and ground circuits. Ignition voltage is supplied to the sensor by an independent circuit. The CKP sensor produces a magnetic field whenever the ignition is ON. The CKP sensor is mounted near a reluctor wheel that is attached to the crankshaft. When the crankshaft rotates, when the engine is cranking or running, the toothed reluctor wheel changes the magnetic field. The CKP sensor converts each change in the magnetic field into a PULSE. The number of teeth on the reluctor wheel determines how many pulses the CKP sensor detects per crankshaft rotation. The CKP sensor signal is used in order to determine the engine speed, the crankshaft position, and to detect misfire.
If the VCM does not detect a CKP signal during engine cranking for a predetermined amount of time, then this DTC will be set.
CONDITIONS FOR RUNNING THE DTC
^ The engine is cranking.
^ Four or more camshaft position signals are detected.
CONDITIONS FOR SETTING THE DTC
The crankshaft position sensor signal not detected for more than 0.5 second.
ACTION TAKEN WHEN THE DTC SETS
^ The control module illuminates the Malfunction Indicator Lamp (MIL) if a failure is detected during 2 consecutive key cycles.
^ The control module sets the DTC and records the operating conditions at the time the diagnostic failed. The failure information is stored in the scan tool Freeze Frame and Failure Records.
CONDITIONS FOR CLEARING THE MIL OR DTC
^ The control module turns OFF the MIL after 3 consecutive drive trips when the test has run and passed.
^ A history DTC will clear if no fault conditions have been detected for 40 warm-up cycles. A warm-up cycle occurs when the coolant temperature has risen 22°C (40°F) from the startup coolant temperature and the engine coolant reaches a temperature that is more than 70°C (158°F) during the same ignition cycle.
^ Use a scan tool in order to clear the DTCs.
An intermittent may be caused by any of the following conditions:
^ A poor connection
^ Rubbed through wire insulation
^ A broken wire inside the insulation
Thoroughly inspect any circuitry that is suspected of causing the intermittent complaint. Refer to Testing for Intermittent and Poor Connections in Diagrams.
If a repair is necessary, refer to Wiring Repairs or Connector Repairs in Diagrams.
Sep 23, 2018 at 11:31 AM
RELTNEE5199
Wired the sensor as per diagram. Now get code p0339 and p0336. Is there a way to test crank senor out of the car? Can I rewire the sensor? Thank you for your time and efforts.
Sep 24, 2018 at 7:19 AM
Check the connector and the sensor for any damaged pins. Make sure the connection is tight.
CIRCUIT DESCRIPTION
If a loss of the CKP signal or an erratic signal is detected by the VCM while the engine is running, this DTC will be set.
The MAF is 5 g/s or more.
^ The measured change in engine speed is more than 1,000 RPM during a 125 ms time period, or
^ The measured engine speed is 0 RPM and 4 or more camshaft position sensor pulses have occurred over a period of 2 to 3 seconds
DIAGNOSTIC AIDS
Inspect the face of the CKP sensor for metallic particles. This could result in an intermittent DTC.
Check for the following conditions:
^ A chipped or damaged reluctor wheel
^ An incorrect reluctor wheel
^ The incorrect alignment of the CKP sensor to the reluctor wheel
^ Excessive crankshaft end play
^ Refer to Symptoms. See: Computers and Control Systems > Symptom Related Diagnostic Procedures
^ A poor connection
Sep 24, 2018 at 7:29 AM
