I keep getting the code PO339 which is bad crankshaft sensor. So far I replaced the old one with one brand new and two used ones and still have same issue. The crankshaft bracket was also damaged and I replaced it as well. It is two wire sensor and I have checked the ground for continuity. It was okay.
The engine will start and idle for about thirty seconds and all of the sudden stall. When I attempt to start it again, most of the time it will start right away. Sometimes it will hesitate and not start until second or third try. I also tried to warm up engine and it will behave the same. Do you have any idea what could be the cause of this? I am thinking perhaps to replace connector next, because that was the only thing I did not replace so far. Please let me know what you think.
Feb 14, 2018 at 6:18 PM
