Crankshaft sensor installation
1,600,000 MILES
ANDRE BATTIS
  • 16 POSTS
Where do I mount the sensor?
Jun 10, 2021 at 6:12 PM
Good morning,
I attached the procedure below for you to view. It is external and does not require removing the front cover.
When you release the bolt, twist the sensor before pulling it out. That will release the o-ring and make it easier to remove.
Jun 10, 2021 at 8:57 PM
