It just and cranks, then sounds like free spooling?
200,000 MILES • 1.5L • 4 CYL • 2WD • AUTOMATIC
JAMESP9557
  • 7 POSTS
Replaced the front crankshaft seal.
Started up with super high idle so, I turned it off, went to turn back on to adjust and cranks, then sounds like free spooling and like it is struggling to turn over. Free spooling sounds like the starter spindle not engaging. But I didn't even touch that part of the car.
May 30, 2023 at 2:45 AM
  • 55,743 POSTS
Sure, I would disassemble the front cover to see if the timing belt is turning when the engine is cranking over.
Here is a guide to help you:
https://www.2carpros.com/articles/comprehensive-guide-to-diagnosing-and-repairing-a-bad-timing-belt
Please go over this guide and get back to us.
May 30, 2023 at 12:01 PM
JAMESP9557
  • 7 POSTS
Timing belt is brand new. Just replaced starter again. Still aou.ds like free spooling and not engaging with flywheel at all.
May 31, 2023 at 11:20 AM
  • 55,743 POSTS
Can you please shoot a quick video with your phone so I can hear the noise? That way I can tell for sure what's going on. You can upload it here with your response.
It sounds like the engine has no compression but to confirm check out this guide:
Jun 2, 2023 at 1:17 AM
JAMESP9557
  • 7 POSTS
Sorry, forgot to post. Got it fixed. Jumped timing. And the tensioner was loose. Re-timed and checked every bolt. Runs great. Thanks.
Jul 22, 2023 at 6:10 AM
  • 55,743 POSTS
Thanks for letting us know, we are here to help, please use 2CarPros anytime.
Jul 23, 2023 at 6:41 AM
