After having the crankshaft front seal replaced and an oil change, it shut off while driving, why?
281,000 MILES • 1.8L • 4 CYL • TURBO • 2WD • AUTOMATIC
MICHELLE912
  • 8 POSTS
So, i had a mechanic put a crankshaft front seal in and an oil change. When it was all done, I drove off and a half mile down the road it shut down on me. why is that?
Sep 24, 2022 at 2:38 AM
  • 110,251 POSTS
Were you able to restart the vehicle? Did this happen while you were traveling or while at a stop?
Let me know as much as you can.
Sep 24, 2022 at 3:32 PM
MICHELLE912
  • 8 POSTS
I got in the car a literally drove a mile down the road it shuttered and lost my RPMs and smoked everywhere, total loss of power.
Sep 25, 2022 at 5:06 AM
MICHELLE912
  • 8 POSTS
But when I checked the car cooled down, I checked the oil, and nothing was on the oil dip stick at all. However, out of the blue it gets towed to the shop, and he showed me the dip stick and it's full of oil.
Sep 25, 2022 at 5:15 AM
MICHELLE912
  • 8 POSTS
And when I was travelling.
Sep 25, 2022 at 7:48 AM
  • 110,251 POSTS
Has anyone been able to identify the cause of the smoke? That is my biggest concern. As far as it not starting, we can figure that out, but I would like to know about the smoke, so we don't further damage something.
When you had the issue, did the smoke have an oil smell or something different?
Sep 25, 2022 at 12:03 PM
MICHELLE912
  • 8 POSTS
No, it did not smell like oil.
Sep 25, 2022 at 1:48 PM
MICHELLE912
  • 8 POSTS
It was where my radiator was.
Sep 25, 2022 at 1:49 PM
MICHELLE912
  • 8 POSTS
Can a bad battery have something to do with it? Because they have had to jump it off a few times as well.
Sep 25, 2022 at 1:55 PM
  • 110,251 POSTS
Okay, the smoke was likely from engine coolant steaming. As far as the battery is concerned, it can cause it. However, it wouldn't have caused the smoke. It sounds like it may have stalled because of overheating. Did you check the temperature gauge when this was happening?
Sep 25, 2022 at 2:00 PM
MICHELLE912
  • 8 POSTS
It was normal that I seen.
Sep 25, 2022 at 4:09 PM
  • 110,251 POSTS
Okay. Then one other thing at the radiator may have been transmission fluid. The transmission cooler is integral to the radiator. There is a supply and return that may have leaked.
I attached a pic below showing the supply line. The return looks the same but is lower on the radiator. Has the transmission fluid level been checked?
See pic below.
Sep 26, 2022 at 11:05 AM
