Crankshaft pulley
150,000 MILES • 2.3L • 3 CYL • 2WD • MANUAL
CONOR ROGERS
I believe I just ruined my engine not knowing it. I put a new crankshaft pulley on and did not line it up with how the old one was and started it up. Just need to confirm this so I can start looking for something else.
Jun 3, 2018 at 6:26 AM
STEVE W.
  • 15,399 POSTS
If you loosened the crank pulley bolt without the holding tool installed then it is very possible that the camshaft drive pulley moved during the process. But you would be better off borrowing the tools and going through the process of aligning them and testing to be sure they did/did not move before you decide it is damaged.
Or did you hear it crash internally once you were finished or it now will not run?
Jun 5, 2018 at 12:42 AM
