Installing the Crankshaft issue, the crank pulley back in it keeps hitting the oil pump?
200,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
JOSH GELDERMANN
when i try to install the crank pulley back in it keeps hitting the oil pump, the part that actually runs off the crank pulley. I've tried lining it up best i can but there has to be a method i can't figure out. am i supposed to just hammer it back in? i really don't feel comfortable doing that, it doesn't seem right. Please tell me what I'm missing.
Feb 6, 2024 at 11:31 PM
  • 110,248 POSTS
I agree. It wouldn't be a good idea to hammer it on. LOL
I'm not sure if it would help, but if the cover is left slightly loose, it may help. One you get it installed, then you can tighten the cover.
Let me know if the pump or pulley is new.
Feb 7, 2024 at 9:22 AM
LANDON DOH
Neither are new. I just finished torquing all the bolts. how would i loosen bolts without messing up the sealant around the whole perimeter?
Feb 7, 2024 at 1:40 PM
LANDON DOH
It's not new. How can i have the cover loose and get the pulley in because I'm supposed to put sealant under the whole outer edges. won't be able to seal it if i put pulley in first.
Feb 7, 2024 at 7:13 PM
  • 110,248 POSTS
Yep, that is correct. The only thing you can do is try to move it in different directions to see if it will align with the pump. If it won't align, something inside the pump may not be aligned properly.
I wish I had a better answer, but that is the bottom line.
Feb 8, 2024 at 7:18 AM
