Crankshaft pulley bolt removal torque psi
1995 TOYOTA COROLLA
V6 • FWD • AUTOMATIC
ROCKYTALKIE
I need to know what psi is required from my compressor to create the proper tourqe to remove the crankshaft pulley bolt on my 1995 Toyota Camry V6
Jun 1, 2015 at 1:48 PM
  • 31,937 POSTS
It is not so much the psi of the compressor, most will run at around 150PSI it is the capacity of the impact gun and they all vary, often you will require a 3/4 drive impact gun as these operate at a higher torque rating than the smaller 1/2 drive.
Jun 1, 2015 at 7:12 PM
