Crankshaft positioning sensor replacement
176,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
JEREMY_UBER
I got a code saying my sensor was faulting then my car wouldn't start. so i replaced the sensor. the engine light went away and it started no problem for about 2 weeks. then the check engine light came back on and its having problems starting again. since i bought a cheaper sensor online,should i replace it with a better part? i took it out and cleaned it and it started again but still have the engine light on. is there something else it could be? and do i need a mechanic?
Aug 6, 2019 at 5:51 AM
If the engine starts then the crank sensor is okay. However, the check engine light means we have a code and we need to scan it for codes to find out what they are. Here is a guide that will help with that:
However, if this is a crank sensor issue, this guide could help with figuring out if it is related:
Let's get the codes and go from there. Check out the diagrams (below). Let us know what happens and please upload pictures or videos of the problem.
Dec 24, 2020 at 9:54 AM
PATACAKE
  • 28 POSTS
could you please send me a diagram of where my crankshaft sensor is located on my car? i do thank you so much.
Dec 26, 2020 at 2:23 AM (Merged)
JDL
  • 16,098 POSTS
This is what it looks like. I haven't found a good picture of the location, yet.
JDL
  • 16,098 POSTS
Just to add.
JDL
  • 16,098 POSTS
Here you can see the wiring colors at the connector.
2CP-ARCHIVES
  • 4,540 POSTS
where is crank sensor location
  • 110,248 POSTS
It should be behind the harmonic balancer in the front of the engine.
SNYDER3410
Car shutting down when hot.Code PO 335 (Crankshaft position sensor A circuit malfunction).Bought new sensor and replaced.Car would not start.Put old sensor back in.Car starts but same quitting problem. Assumed i had a bad part.Replaced part and re installed. Car still won,t start??
Dec 26, 2020 at 2:24 AM (Merged)
WRENCHTECH
  • 20,760 POSTS
If it starts with the old part and not the new one, there has to be something different about the new sensor. Maybe you should try a different brand.
DOCFIXIT
  • 18,828 POSTS
Just a thought but did new Crank sensor have a removable paper sticker on it to be removed before install?
SKEENA
what is the secret of getting the sensor out? I have taken out the bolt and unhooked the harness , the sensor is loose but will not come out.
BLUELIGHTNIN6
  • 16,542 POSTS
that's all there is to it , should come on out . there is recall on this vehicle about the sensor though so your local nissan dealer should replace it free of charge..
SKEENA
I called Nissan and the CSR said that recalls are VIN specific and stated that there were no recalls on my VIN.
As to the removal of the sensor, it was the O ring hanging up. Thank your for your replay.
KIMANDGAYLE
  • 9 POSTS
How many ohms should the camshaft sensor read and how many ohms should the crankshaft sensor read?
Dec 26, 2020 at 2:27 AM (Merged)
ZACKMAN
  • 4,202 POSTS
https://images.2carpros.com/forum/automotive_pictures/55316_02sentracmps_1.jpg
https://images.2carpros.com/forum/automotive_pictures/55316_02sentrackps_1.jpg
KIMANDGAYLE
  • 9 POSTS
Thanks for the ohms and volts chart. I checked both sensors, checked out good. Fuel pressure is 59PSI. I cleaned the air intake sensor, but nothing has changed in the way it runs. Took it for a 10 mile run, when I accelerated (under a load) it would kick and buck as if I turned the key off, then back on. Probably 6 out of those 10 miles, the engine runs fine. It is as if an injector or coil is bad when it drops off, but it is like it is all of them simultaneously. At idle, it may run fine for 2 to 3 minutes, then just die. Starts right back up. I checked the wiring harness for maybe problems there, but nothing noticeable. There is no consistency to the problem, hot/cold, high/low rpm, acts the same. No codes are present, no check engine light. I have access to a snapon scan tool. Scratching my head. Would a fuel pump relay be intermittent to cause the engine just to drop off, shouldn't it slowly die if it were the relay? I am puzzled.
ZACKMAN
  • 4,202 POSTS
Try this diagnostic procedure.
https://images.2carpros.com/forum/automotive_pictures/55316_02sentrasurge_1.jpg
KIMANDGAYLE
  • 9 POSTS
I rechecked some items and checked others. Fuel pressure is 75 PSI dead headed and car running. Vacuum at manifold is 20. Checked fuel pressure regulator (working), checked for water in fuel, ran about 3 gallons out of return line while car was running. Camshaft and crankshaft sensor checked out exactly the same in ohms and volts. When it runs with out dieing, it is smooth. I am going to try and acquire the scan tool again and use it to watch each sensor voltage and action. Hopefully this will reveal something.
ZACKMAN
  • 4,202 POSTS
Did you happen to check the MAF sensor? I remembered a while back an 00 Sentra with 1.8L with somewhat similar symptoms, and the driver cleaned grease from her sensor, and the car worked great right after.
KIMANDGAYLE
  • 9 POSTS
Yes, cleaned an already clean MAF.
ZACKMAN
  • 4,202 POSTS
Then get your hand on the scan tool and check each sensor operates, let me know..
REELKEY
where is the crank shaft censor? and how do you change it
  • 75,988 POSTS
The CPS is on right rear side of cylinder block
https://images.2carpros.com/forum/automotive_pictures/12900_cps_30.jpg
JOHN W. GRAHAM
Where is the crankshaft positioning sensor and how do I go about replacing it?
Dec 26, 2020 at 2:28 AM (Merged)
  • 75,988 POSTS
See location below:
https://images.2carpros.com/forum/automotive_pictures/12900_ckp_2.jpg
Testing and Inspection Component Inspection
https://images.2carpros.com/forum/automotive_pictures/12900_c1_9.gif
https://images.2carpros.com/forum/automotive_pictures/12900_c2_8.gif
Disconnect crankshaft position sensor (POS) harness connector. Loosen the fixing bolt of the sensor. Remove the sensor. Visually check the sensor for chipping.
https://images.2carpros.com/forum/automotive_pictures/12900_c3_6.gif
Check resistance as shown in the figure. If NG, replace crankshaft position sensor (POS).
DAYLE P
where is crank position sensor and what tools do i need to replace it
IMPALASS
  • 3,112 POSTS
Located on lower left front of engine. It may be held in by a 10mm bolt. However, depending on clearance you may need a wrench. So this will have to be determined once you are looking at it.
