Can I get the Crankshaft position sensor wire diagram?
170,000 MILES • 2.4L • AUTOMATIC
AMANDAA
I need help with getting the Crankshaft position sensor wire diagram.
Nov 16, 2023 at 1:19 AM
  • 110,248 POSTS
I attached the wiring schematic for the sensor. Also, I highlighted the wiring from it and where it goes to. Note that all three sensor wires go to the engine control module (ECM) which is located near the battery.
Additionally, I had to cut the pic in half to make it readable. I did overlap it so you can follow from one to the next.
Let me know if this helps or if there is anything I can do to help.
Nov 16, 2023 at 1:07 PM
