The short answer is, yes and no.
The long answer is that the ECM uses the crankshaft signal, along with cam position sensor in order to determine firing of the injection and ignition.
It also uses it to determine if the engine is misfiring by reading the amount of time between the signal pulses and comparing that to the data table it has been programmed with on how long those pulse separations should be.
Because of manufacturing changes and differences each sensor is slightly different in signal output and even in where it reads the signal depending on the position of the sensing part inside the actual head of the sensor.
The relearn procedure "resets" the sensor information so the ECM can learn the new sensors signal. If it is not done you can get mis-fire codes and poor engine performance or in newer engine a reduced power condition.
A dealer is not the only place that can do a re-learn, pretty much any good shop with a bi-directional scan tool can handle it as it is a very common item to be done, even for some diagnostic work.
Aug 10, 2017 at 11:56 PM
