Where is the crankshaft position sensor located, and replacement directions needed?
52,000 MILES • 4.3L • 4 CYL • 2WD • MANUAL
SEASHAANN
I found out that my truck listed above needs the crank shaft position sensor, and I do not know where it is or how to do it.
Oct 27, 2024 at 11:29 AM
BORIS K
  • 836 POSTS
The crankshaft position sensor is located at the front crankshaft pulley, at about 10 O'clock.
See image below.
A good video on how to replace:
https://youtu.be/fmg62oQaK6Q?si=_RdjKykJtpek0BSN
You will need to remove the battery to make space to remove the intake air pipe.
How to remove battery:
https://www.2carpros.com/articles/how-to-replace-a-car-battery
Cheers, Boris
Oct 27, 2024 at 8:12 PM
